Bendix 0526 AA5 Problem
Nice sets. I had to do some cabinet repair on mine and, as a result, needed to paint it. So I took my inspiration from one of BUZZ1151's YouTube videos and painted mine in the same tri-color scheme:
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
