AK 559N Restoration
http://www.russoldradios.com/blog
It took a while - -
Beautiful job Russ. Icon_thumbup Your attention to the details is most inspiring to me. Especially when I'm tempted to take a short cut.
Glad you saved it from the parts pile.
Looks great Russ.  As Mike said you're setting the bar very high Icon_thumbup
Another beautiful job Russ!!
Icon_clap Icon_clap Icon_clap
(02-23-2017, 05:46 PM)Eliot Ness Wrote:  Looks great Russ.  As Mike said you're setting the bar very high Icon_thumbup
I used to pole-vault over the bar, now I climb a ladder and fall over it.
Hmm, rubber covered wire, and weird in house made A.K parts. Still the set is probably a good perfomer, good looking, so still worth the effort.
Arran, the construction of this set is typical for AKs made up till the end. Most if not all are sought after by collectors. In my opinion, this cabinet and the one used on the 447 (both were used for several models) are among the most attractive offered by Atwater Kent. This 9 tube chassis with shadow meter is probably in the upper 1/3 of radios made that year as far as performance goes. Like with Philcos (who also used "custom" resistors/colors) many parts have not survived the years.
Yep, familiar suffering.
And there's that cap block which is a PITA to gut. I decided to open it as a box and heated it with heatgun AND iron till the solder had melted and I pulled it apart. Then soldered it back closed.
Philco 89 indicator light.
There are currently 9527 online users. [Complete List]
» 1 Member(s) | 9526 Guest(s)
