Parts for a 42-380
I believe I have a Philco 42-380, don't know for sure as it has no marking on any stickers.
It has been rebuilt once.. but poorly
I want to do it over, does anyone here know a list of parts for a 42-380x
or where I can find them. Radiodaze.com is having free shipping and would love to get it all!
Nostalgia air has the schematic and parts list:
http://www.nostalgiaair.org/PagesByModel...013533.pdf
The top 4 photos below are my 42-380:
Steve D
Admin note: Broken links in this post were removed.
Nice 42-380, thanks for the pictures. I'm using them as the basis for my restoration. Regarding Nostalgia air's schematic and parts list, my download is unreadable. Were you able to utilize it?
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
