An Original Philco Hippo
I guess I was wrong about the pilot lamp choice being related to the rectifier tube used, not that it matters as you can omit using the pilot lamp tap on a 35Z5, 35Z4, or a 35W4 without incident. However with a 50Y6 or a 35Z3 there is no tap, so if you want a pilot lamp you have to use a 120 volt night light or Christmas light bulb.
Dan you could use a 35Z4 in your radio with no problem. David
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4849 online users. [Complete List]
» 2 Member(s) | 4847 Guest(s)
