Threads: 140
City: Lansdale
State, Province, Country: PA
All My next attempt ... Its a Zenith 5D011 Consoltone radio. Looks pretty good..
[Image: http://i292.photobucket.com/albums/mm38/...tg11oa.jpg]
The Grill cloth is a little dirty...
In sides not to bad pretty open..
[Image: http://i292.photobucket.com/albums/mm38/...wggurw.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...vzcc25.jpg]
I hope all Coils and IF's are OK.. Thats the next checks.. Then test tubes..
More to follow...
Skip...
Threads: 140
City: Lansdale
Ok, All coils and IF caps and Output Transformer check out OK..
I did notice a wrong value of resistor in radio Its R6 I think Value 220 Ohms.. There is a 1K resistor in there.. Not really sure if it is original...
Will it make any difference?
[Image: http://i292.photobucket.com/albums/mm38/...yza9hn.jpg]
Skip...
Threads: 416
City: Boston
Neat set, a brown version of this is featured in a late 3 Stooges, with Shemp. They are income tax preparers, the red lite when on is cool. Good luck.
Threads: 140
City: Lansdale
All, As I was recapping I found this.. Its C3 .05 uf to ground. Parts list says its a .05 200 Volt.. However whats in it is a .05 at 1000 Volts.. Is that a replacement that someone had ?? Or original..
Here are pictures...
[Image: http://i292.photobucket.com/albums/mm38/...zqlmwf.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...2eipxe.jpg]
Actual Part...
[Image: http://i292.photobucket.com/albums/mm38/...hhvxpp.jpg]
Thanks
Skip...
Threads: 140
City: Lansdale
Ok, Since no answers.. I put together 2 .1 600 Volt caps in series to make a .05 at 1200 Volts and put in ..
Finished wiring up the E-Caps and tomorrow will power it up..
Skip..
Threads: 567
200V is more than enough.
Threads: 14
City: Irvington, NY
You might want a high voltage cap in that location. It connects between the chassis and AC line.
Depending on which way the line cord is plugged in, its either neutral or hot connected to the chassis if the cap shorts.
Threads: 140
City: Lansdale
Ok, Thanks all.. Completed the Caps and resistors replacement. Plugged in and brought up slowly. At 117 Volts draws .25 amps.. Radio plays and picks up many stations.. On to alignment as dial is off a little..
Skip...
Threads: 11
City: Bellmawr, NJ
Wow,,,there must be 3 ,,,R-6's,,,there are 2 together,,,470,000 ohms,,,thee other may ?? be a mistake , (Label) ,better Check you parts list closely,,,CHEERS
Threads: 11
City: Bellmawr, NJ
on Zenith 6D015---R-3 is 1000 ohms----which is in the SAME location off the tube 12SA7GT of YOURS ( R-6,,220 ohms resistor),,which READS 1K,, CHEERS again
Milkjug plastic?morzh — 09:36 PM |
Yep.
'Cause when I heard "buibble" I immediately thought of this
and started wondering how this poly...morzh — 09:33 PM |
Blister Pack, that's what I was trying to remember!RodB — 09:29 PM |
In the packaging biz we refer to the package as a clamshell or blister pack if on a cardboard. So we are using the packa...Paul Philco322 — 08:13 PM |
It’s been too cold to solder in the garage the last couple of evenings, but it has allowed me more time to search for th...jrblasde — 07:23 PM |
The part/tool you get from HD is inside the plastic, like in a bubble.RodB — 07:17 PM |
Got it. Still did not get the "Bubble" part.morzh — 07:10 PM |
No Mike. Clear plastic from the packaging of items you buy at Home Depot, the ones you can't open without a hack saw or ...RodB — 05:48 PM |
Philco 89 indicator light.
Well thankfully that did not happen.Jim Dutridge — 05:21 PM |
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!
PS. Looked it up. They have kits and parts for mod...morzh — 02:45 PM |
There are currently 9645 online users. [Complete List] » 1 Member(s) | 9644 Guest(s)
