Threads: 140
City: Lansdale
State, Province, Country: PA
All My next attempt ... Its a Zenith 5D011 Consoltone radio. Looks pretty good..
[Image: http://i292.photobucket.com/albums/mm38/...tg11oa.jpg]
The Grill cloth is a little dirty...
In sides not to bad pretty open..
[Image: http://i292.photobucket.com/albums/mm38/...wggurw.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...vzcc25.jpg]
I hope all Coils and IF's are OK.. Thats the next checks.. Then test tubes..
More to follow...
Skip...
Threads: 140
City: Lansdale
Ok, All coils and IF caps and Output Transformer check out OK..
I did notice a wrong value of resistor in radio Its R6 I think Value 220 Ohms.. There is a 1K resistor in there.. Not really sure if it is original...
Will it make any difference?
[Image: http://i292.photobucket.com/albums/mm38/...yza9hn.jpg]
Skip...
Threads: 416
City: Boston
Neat set, a brown version of this is featured in a late 3 Stooges, with Shemp. They are income tax preparers, the red lite when on is cool. Good luck.
Threads: 140
City: Lansdale
All, As I was recapping I found this.. Its C3 .05 uf to ground. Parts list says its a .05 200 Volt.. However whats in it is a .05 at 1000 Volts.. Is that a replacement that someone had ?? Or original..
Here are pictures...
[Image: http://i292.photobucket.com/albums/mm38/...zqlmwf.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...2eipxe.jpg]
Actual Part...
[Image: http://i292.photobucket.com/albums/mm38/...hhvxpp.jpg]
Thanks
Skip...
Threads: 140
City: Lansdale
Ok, Since no answers.. I put together 2 .1 600 Volt caps in series to make a .05 at 1200 Volts and put in ..
Finished wiring up the E-Caps and tomorrow will power it up..
Skip..
Threads: 566
200V is more than enough.
Threads: 14
City: Irvington, NY
You might want a high voltage cap in that location. It connects between the chassis and AC line.
Depending on which way the line cord is plugged in, its either neutral or hot connected to the chassis if the cap shorts.
Threads: 140
City: Lansdale
Ok, Thanks all.. Completed the Caps and resistors replacement. Plugged in and brought up slowly. At 117 Volts draws .25 amps.. Radio plays and picks up many stations.. On to alignment as dial is off a little..
Skip...
Threads: 11
City: Bellmawr, NJ
Wow,,,there must be 3 ,,,R-6's,,,there are 2 together,,,470,000 ohms,,,thee other may ?? be a mistake , (Label) ,better Check you parts list closely,,,CHEERS
Threads: 11
City: Bellmawr, NJ
on Zenith 6D015---R-3 is 1000 ohms----which is in the SAME location off the tube 12SA7GT of YOURS ( R-6,,220 ohms resistor),,which READS 1K,, CHEERS again
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
There are currently 6388 online users. [Complete List] » 1 Member(s) | 6387 Guest(s)
