35A5 tube substitution
Thanks for the info. I'm learning a lot about tubes . Now if I can just remember it .
walt
Could be since your filament voltage is low, (due to the 50A5) is the reason your radio has 'other problems'.
Tim
Yeah that could be. But I noticed that somebody before me had worked on the speaker extensively and probably couldn't fix it .
Strangely ,I just discovered that a Philco 41-225 that I have has exactly the same chassis as the 41-220 except for the push button feature and it also has a 50A5 tube in it and it works OK. I do have a 35A5 coming and I will use it .
But I am sure the speaker has problems and I'm looking to get it rebuilt or purchase a good used one IF I can find one. There should be one out there somewhere since they probably made thousands of these radios. Thanks for your input.
walt
Ooh, very nice!jrblasde — 12:19 PM
I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye. It has 13 tu...Dan Walker — 12:07 PM
Hi guys! I’m a new member here but have been using your resources for quite some time. Hopefully I can get some help wit...Radios1340 — 11:52 AM
There are currently 7070 online users. [Complete List]
» 1 Member(s) | 7069 Guest(s)
