38-93.....so far
#31
HOW DID YOU FRY YOU FREQUENCY COUNTER,,MAY I ASK,,,SOO,,I DON'T DO THAT WITH MY $9.00 ONE,,,CHEERS
#32
Ken,
Have you gotten your Caps Lock key stuck today? Icon_lol
#33
I don't know. It just went haywire. I had taken it loose and may have touch the lead to the HV when I moved the chassis. Other than that I don't have a clue. I ordered 2 more from FeeBay.
"He has all the virtues I dislike and none of the vices I admire." — Winston Churchill
#34
The more I looked a this thing, the more I disliked all the yellow capacitors. Icon_thumbdown So I dug around and found some micas that were close enough to what was called for, and re-stuffed the tubular capacitors in their original tubes (all two of them). Call me OCD, but I think it looks better. Icon_biggrin
Kelly
#35
It does!
#36
Thanks morzh.
#37
Lately I've been restuffing the caps for most radios I work on. Even though no one will probably see it for a long time - or even care - I know they're there. Icon_smile
#38
Hmmm. I wonder if that frequency pointer would work on my Scott 16...  Anyone have a spare?
#39
Wanted ads go in Wanted Ads, not here. No ads allowed except in For Sale or Trade and Wanted Ads.
I think if,,,,I was stuffing CAPS,,,,,I have to leave a NOTE in the chassis,,,lololol
91H Code 126 Restore
Philco 70 antenna lead
There are currently 2477 online users. [Complete List]
» 1 Member(s) | 2476 Guest(s)
