Threads: 242
City: West Bend, Wisconsin
I have a friend who has a nice cabinet for this model. However it's a battery powered set and he would like to find a similar 1937 Philco chassis to put in the cabinet that runs on AC. Would a 37-640B chassis fit in a 623 cabinet or which model(s) would work?
Threads: 54
Is it a complete 37-623B or just the cabinet from same? If it has the chassis and speaker with it I think I would just restore the set as is, and build a power supply for it. I'm not sure whether a 37-640B chassis would fit in the cabinet or not, the 37-640 has seven tubes and a power transformer, get someone who has one to measure it.
Threads: 242
No I think he just has the empty cabinet. He said it's in beautiful shape so I think he may be better off trying to find another 37-623B with a bad cabinet and steal the chassis and speaker from it. I suspect there is something different between the 640 and 623 size wise. He may be forced to build a power supply or get an ARBE III. I thought perhaps Ron or someone may have encountered those two models over the years for comparison sake.
oops, I thought I answered this this morning...still half asleep, I guess...
A 37-623B cabinet is the same as a 37-620B cabinet.
As for physical size of chassis, when considering AC-only chassis, the following will fit:
37-610, 37-620, 37-630, 37-640, 38-610, 38-620, 38-630
The 37-640 is indeed the same physical size as the 37-630, 37-620, etc. It does use seven tubes, but everything is crammed into a smallish chassis. I have a 37-640 chassis in my 38-624T Big Bullet cabinet, it fits just fine.
Threads: 242
Thanks Ron! I appreciate it.
Threads: 242
D'oh! Turns out he has an empty 37-623 CONSOLE cabinet, not a tombstone. I'm sure the chassis' you listed will fit, but now to figure out if he needs an 8" or 10.5" speaker to go with it?
The 37-623J (console) used an HR-12 speaker which is 10-1/2 inches. So...you know that you will need a suitable 10.5" speaker to go with whichever chassis you install.
Threads: 242
Thanks, Ron. That looked like what it needed based on your spreadsheet. Just wanted to make sure. Will see what I can find at the WARCI meet tomorrow morning.
New member
Hello jeff,
Welcome aboard !
Sincerely Riochardradiorich — 06:53 PM |
New member
Good picture,
When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM |
New member
Love the pic! I'm southern IL, so wouldn't be much help and Bob Anderson is very good on those, but lives in Chicago are...TV MAN — 05:25 PM |
:thumbup:klondike98 — 04:56 PM |
With these values I think you are OK; the Cmax for this tube is 40uF.
Your Vbb could rise a bit, but probably not too mu...morzh — 04:53 PM |
BTW, someone had replaced the original 20uF/20uF filter cap with a 47uF/33uF cap. Do you think these values are safe on ...bluecap — 04:33 PM |
You're correct. I was misinterpreting the key position. I now know where it is, and things are making sense. I appreciat...bluecap — 04:29 PM |
I think Morzh has a good thought. Check the key position. The under chassis diagram in the Philco info shows an “H” for ...klondike98 — 04:25 PM |
Philco 630csx power cord
Yes, the third wire goes to the stud on the side and is separate from the other two.
I've usually used cloth covered ...Tynwald — 03:09 PM |
New member
Have you tried Alabama Historical Radio Society?
They possibly could recommend someone.
I remember a name of Dee Hanes...morzh — 03:08 PM |
There are currently 4896 online users. [Complete List] » 2 Member(s) | 4894 Guest(s)
