VTVM EICO 232 LM317 BATTERY CHANGE
Did this a while ago. Transformer fused in out. Very stable ohms.
More of the LM317 battery replacement
More Eico 232 LM317 REPLACEMENT
I have a slightly older Eico where the previous owner rigged up a substitute for the battery by tapping off the filament winding of the transformer, all he used was some diodes, a resistor, and some large value, low voltage, electrolytics. It worked fine for me until I blew out one of the resistors on the Ohm meter section after I accidentally used to to measure some high voltage.
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 2452 online users. [Complete List]
» 2 Member(s) | 2450 Guest(s)
