Frayed Wires at Speaker Plug
The Philco 70 I'm restoring( at least attempting) has bare, frayed speaker wires at the male 4 prong connector that plugs into the rear of chassis. Can I drill out the two rivets,separate the plug and then cut and resolder the wires were the insulation is still good? If this will not work maybe I can cut off the plug and replace with a 4 pin "CP" plug? Thanks in advance for your help.
Bill
EXCOT Wrote:The Philco 70 I'm restoring( at least attempting) has bare, frayed speaker wires at the male 4 prong connector that plugs into the rear of chassis. Can I drill out the two rivets,separate the plug and then cut and resolder the wires were the insulation is still good? If this will not work maybe I can cut off the plug and replace with a 4 pin "CP" plug? Thanks in advance for your help.
Bill
Yes, absolutely. This is standard operating procedure, especially if you are replacing the old wires with new cloth-covered wires.
Just be careful drilling out those old rivets. That bakelite plug can break quite easily.
I have a similar situation. Does anyone know a source for replacement rivets?
I use 3-40 or 2-56 brass screws and nuts and put a "old" patina on them. I put the screw head showing when plugged in and make sure there is only enough screw length to catch the nut for clearance.
Mi dos Centavos
Thanks Ron and Chuck. I carefully drilled off most rivet head on inside of plug with like a 3/16 bit. With a pliers I was able to lift up what was left of rivet head and then I pushed out by hand with correct size punch. When I reassembled I pushed original rivets back in with slip joint pliers and used a center punch to carefully flare rivet head (what was left of it) back out. The brass is soft so it doesn't take much and I followed Ron's suggestion and was careful with bakelite. Then I put drop of super glue down on head to help secure rivet to bakelite. It's not as strong as original but for my needs it should be ok. Bill
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
