My new Philco 70 cathedral
Threads: 40
City: Sanger, CA
Got this early 70 recently and just finished detailing the cabinet. It has a beautiful original finish! I can't imagine a nicer original 70 out there! I did the Gojo clean-up (it had a dark grunge all over it), with a quick wipe-down of Howards. When that dried, I waxed it with Johnson's Paste Wax. Very happy with how it came out. I only wish I could do the chassis too, but my 1st grade electronics knowledge won't allow that.....
I've added a photo of the bottom of the cabinet. It shows a date stamp of SEP 17 '8. I didn't know they were building these models that early (1928). Could this cabinet be a leftover for an earlier model?
[Image: http://www.surfacezero.com/g503/data/500...011107.JPG]
[Image: http://www.surfacezero.com/g503/data/500...011108.JPG]
[Image: http://www.surfacezero.com/g503/data/500...011109.JPG]
[Image: http://www.surfacezero.com/g503/data/500...011117.JPG]
(This post was last modified: 04-27-2017, 04:15 PM by SteveG.
Edit Reason: added picture and text
Threads: 566
Looks very nice indeed, Steve.
I take it, you haven't restored the chassis yet?
Threads: 40
City: Sanger, CA
No Mike. Like I said, I'm electronically challenged and at this stage in my life, it's too late to fix that. 20-30 years ago, I wanted all my radios to work. That wish was made easy with a local old school radio guy who fixed them very reasonably. He passed away back then and I paused on my collecting for about 20 years. A couple of years ago, I got the bug again and started adding to the radios I had collected back then. Some have had the chassis done and some not. Right now, I'm content to acquire nice ones and worry about the chassis later.
Threads: 271
City: Wilsonville
State, Province, Country: OR
That's a nice looking set!! congrats!
Chassis looks nice and clean as well. Clearly someone put a new power cord on it at some point.
Threads: 40
City: Sanger, CA
Thanks Bob. I'm tempted to cut that power cord so no one plugs it in until it's serviced. I'll add a picture of the dated bottom of the cabinet later today.
(This post was last modified: 04-27-2017, 02:47 PM by SteveG.)
Threads: 40
City: Sanger, CA
Added photo of the dated bottom of the cabinet.
(This post was last modified: 04-27-2017, 04:16 PM by SteveG.)
Threads: 14
City: Irvington, NY
Steve, I would not cut that power cord off just yet. I have a feeling this radio may have been restored, at least to some extent. Its a fairly recently installed cord from the looks of it and I doubt anyone would go to the trouble of replacing it without at least installing new filter capacitors.
If you can remove the chassis from the cabinet and take a photo of the underside of the chassis, folks here would be able to tell if any recent restoration work has been done on it.
Threads: 566
The speaker plug has not been touched, the wires coming into it seem a bit frayed.
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
