Threads: 20
City: Decatur Alabama
I am trying to adjust the shadow meter on an early 16B. I have read and reread Philco Repair Bench instructions on doing this but one question remains- how do I get hold of the dang coil to move it back and forth and rotate it? I had to take the bottom off just to get enough grip on it to prove to myself that it actually will move. Is there a tool that fits in the small slots on the side of the coil? Thanks folks,
Doc
Threads: 268
I don't know that the coil can be moved. It's got a bracket over it that pretty much locks it in place. The only adj I've done is making sure the lamp is in the proper place. Maybe I'm missing something.
[Image:
http://philcoradio.com/phorum/attachment.php?aid=11689]
(This post was last modified: 05-11-2017, 07:20 PM by
Radioroslyn.)
Threads: 569
I don't think the coil should be touched.
Why would you try to move it?
Threads: 268
If you could move it you still can't change the position it sits above the vane, that's fixed.
Threads: 214
City: Seattle
State, Province, Country: WA
The
Philco Repair Bench instructions which mention rotating the coil are referring to the newer style of shadow meter found on 37-XXX and newer Philcos.
Your 16B (should) have the older 'box' style shadow meter with a coil like the one Terry posted - or see the same repair bench link. The only thing you can adjust there is the lamp position (gently bend the arm) - and possibly the filament orientation (rotate the bulb).
