Threads: 562
Terry just couldn't stand the thought of me leaving without anything to repair so he made me take his Tektronix 465 scope to look at.
Once powered, it looked like the H-sweep amp malfunctions: I can see the flickering but cannot find the beam.
Sure'nuff, once I started to look at the H-output amp, I found a bad 2N2222A transistor. The Emitter junction is open. Q1274 namely, if someone wants to bother looking.
Another thing, the 110V power to the output seems to be 150V. Wonder why.
Anywhoo, Terry, if you have 2N2222A little buggers, get me some by mail.
Threads: 268
Oh you mean the 2n2222a the most popular transistor on the planet??? For a guy who mostly services vt stuff I'm pretty sure I have some.
(This post was last modified: 05-15-2017, 11:46 PM by Radioroslyn.)
Threads: 562
I will see if we have anything close in junk at work. I do not have any at home - no need for them......
PS. Was able to solder gold-plated lead clippings I save (come handy!) to an SMT SOT-23 MMBT2222A transistor which is pretty much the same device. Will try tonight.
Threads: 562
OK. Came after 9pm home from grappling class, decided I had just enough energy left to attempt the repair.
The culprit. 2N2222A transistor.
The sub. MMBT2222A, SOT23 with leads soldered, inserted in the socket.
The channel lines, chopped.
The channels showing the test meander signal from the scope front panel itself.
Ideally, Terry, if you have a 2N2222A, you could put it in, though I think this one is just fine. SOT23 dissipates half of what TO-18 can, but then I do not think there is much dissipation here.
About 1.5hr for the whole thing. Not bad. I never fixed a scope before.
Threads: 268
Threads: 562
Yeah I saw that picture on some tech forum where a guy was trying to fix his 465
Threads: 55
City: Lexington, KY
Great job Mike!
Terry Layman just bought a batch of test equipment and I checked his three Tek scopes for him. The 465 powers on with no trace, the 485 seems dead, but the 475 seems to work OK. So if you want to hone your scope fixing skills I'll let him know
Threads: 562
I thought I never get to fix this one until late summer, as I am deep into 38-690 now.....but it is in waiting for the rebuilt electrolytics which I have yet to cut open and I had a little intermission, so I got to the scope.
It's fun to fix solid state, plus this is something I really know quite a bit better than vacuum technology.
But as everywhere, one's got to be methodical in diagnosing, poke, smell and listen
I have to give proper dues to my mom when it comes to good diagnosis: she was a medical doctor in her pre-American life, and was considered the best everywhere she worked, and for a good reason. She once kind of opened my eye to how to diagnose: pay attention to everything, undress the patient fully and do not be afraid to ask questions, even if people around think the questions are silly. Helps a lot.
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
There are currently 7224 online users. [Complete List] » 1 Member(s) | 7223 Guest(s)
