Philco 66B
Welcome ,,,Happy Trails,,dacsman-----CHEERS
Shoot me a PM dacsman and we'll talk.
Hey Jim,
A little off topic but congrats on getting ur tech ticket!
de N3GTE
Thanks Terry
Would encourage you to keep going and get the General class ticket. A lot more going on on the lower bands (just not right now w/the poor propagation). So are they giving out 2 by 3 calls now for tech?? Those use to be relegated to the novice class and when you pass the tech test you could get a 1 by 3 call.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
