Austrian Hornyphon
Hello . Nice to see the followers of the royal dynasty Princess. Icon_biggrin
Here is my Princess W452 , stylish and beautiful Radio 1952 .
That is a very nice Princess. Similar cabinet to my Potentate. I have acquired a couple pieces of advertising for the 1940 Hornyphon line that I should scan and post. They must have only made table top radios. I have not seen anything showing a floor model.
Sean
WØKPX
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6395 online users. [Complete List]
» 1 Member(s) | 6394 Guest(s)
