Threads: 367
City: Dover, OH
After over a week of trying to get schedules together, I finally picked up this rather small Zenith console this evening. The guy even met me halfway, saving me some miles and I actually got to try a Steak and Shake for the first time ever during the trip. ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif) Overall, the radio seems to be in very good condition with a couple issues that need ironed out. The additional IF can someone added to the back of the chassis seems only linked into antenna wire, with no hacking visible to the chassis. I guess he was selling the radio for his parents who lived in Brunswick, OH and he lives up in Cleveland, which added another issue getting things to jive with his parents to pick up the console. Since this was built the same year as Zenith's Stratosphere and the Baby Strats, I am going to call it the Micro Strat!
I don't think the volume control shaft is supposed to pull out like this! ![Icon_eek Icon_eek](https://philcoradio.com/phorum/images/smilies/icon_eek.gif) Ouch!
Note: I did have to use a little Auto-Enhance with my photo editor as it seems my camera is dying. It now takes rather washed out pictures. ![Icon_thumbdown Icon_thumbdown](https://philcoradio.com/phorum/images/smilies/icon_thumbdown.gif) But, the radio really does look about that sharp in person!
Edit: Actually, it looks better in person. Seems even with auto-enhance, the pictures didn't come out great.
(This post was last modified: 06-03-2017, 07:15 PM by Jayce.)
Threads: 310
City: Kings Park NY
Cool,
It looks a little like an Airline 62-123.
I like
AC: 4 DC: 1
Threads: 55
City: Lexington, KY
I'm glad you finally got to try Steak and Shake..... next you'll say you've never tried White Castle
Anyway, I'm glad you got that radio, it's one I've never seen before and it looks a lot better in your pictures than the Craigslist ad.
Threads: 367
City: Dover, OH
(06-04-2017, 09:12 AM)Eliot Ness Wrote: I'm glad you finally got to try Steak and Shake..... next you'll say you've never tried White Castle
Thanks! I also like the size of it and just the overall design.
Yes, where I live there are certain places we just don't have. The nearest White Castle was up near Akron, OH, but it is now gone. Yes, I did get to go there a few times at least. The closest Steak and Shake is about 20 miles away from me up in North Canton, OH.
Now, getting back to the radio, is there a possibility that control can be repaired? I haven't pulled the chassis for inspection yet.
Threads: 55
City: Lexington, KY
(06-04-2017, 12:42 PM)Jayce Wrote: .......Now, getting back to the radio, is there a possibility that control can be repaired? I haven't pulled the chassis for inspection yet.
Maybe, but you'll need to pull the chassis and take a closer look at the pot.
Threads: 367
City: Dover, OH
I pulled the chassis and, other than being very gummed up, the pot seemed fine. It basically uses a pressed in shaft to work the control pot, which is odd. After several doses of control cleaner to loosen it up, I was able to press the shaft back in tight enough to work for off-on and volume functions with no issues as long as I don't go wild with it. Radio passed the transformer test and actually pulled in a few stations at low power on the bulbs. All good signs! ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif) There are quite a few capacitors crammed under that little chassis though! Almost an un-Zenith like amount!
(This post was last modified: 06-04-2017, 06:48 PM by Jayce.)
Threads: 55
City: Lexington, KY
Jayce, I found your little console in my Zenith brochures. In 1936 it sold for $39.95 and the table version, the 4-T--26, sold for $20.00.
Threads: 367
City: Dover, OH
Ok, I figured it wasn't a high cost model when it was made. Information seems to be hard to find about either version except there was an early and a later version.
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
