GE H-632U
To get rid of the remaining hum you might try a .01 mfd X2 safety cap across the line connected after the power on switch. It is a good idea to add one even if the schematic doesn't have it. Rod
All, Just for Fun I put in a 25L6G tube . tuned to SW band and motor boating was gone. I could now pickup a few SW stations across the band..
When I put the 25L6GT tube back in motor boating started again..
AM Band not affected..
Go figure?? WHY??? the G version works and the GT does not WHO Knows..
Any Clues??
Skip...
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
