91 GRILL CLOTH AND DECAL QUESTUION
I am currently attempting to redo a 91-225 console model.  My question is what is the correct decal for under the tuning knob, and the correct grill cloth type?  I plan on purchasing these items from Radio Daze.  Any help is greatly appreciated.
On my 91B (the cathedral style) the PHILCO is 1/4" high and 1.5" wide. That translates into Radio Daze:
http://www.radiodaze.com/philco-8-decals-dcl-ph8/ I'm not sure if the console decals are the same or not.
The Grill Cloth on mine looks very much like the RAdio Daze Item: http://www.radiodaze.com/grille-cloth-02-item-grc02/
Its also similar I think to the Whisky Rayon that Kenneth Richmond offers: http://richmonddesignsinc.com/grille_cloth_product_page
Thank you, Bob. The Radio Daze GRC-02 looks like the right one.
Anyone??? I think I've found the correct grill cloth, but still unsure of the decal. Looking at some residue on the front of the cabinet, there appears to be a line under the word PHILCO. It looks as though it is part of the original decal.
Bob already answered the decal question - you want DCL-PH8. The illustration on their website is not the same as the actual decals you will receive. The actual decals are the correct font for all 1932-36 and very early 1937 Philcos including model 91.
The PHILCO decal did not have a line under it originally.
Thank you. I wasn't sure if the cathedral style decal was the same as the floor console. Next question. The cloth covered power cord color, is it brown or gold?
Originally brown.
Thank you.
There are currently 9750 online users. [Complete List]
» 1 Member(s) | 9749 Guest(s)
