Recommendation for precise 10.7 mc FM signal generator
I am looking for recommendations on how I might find a precise, preferably crystal-controlled, 10.7 mc FM generator without breaking the bank.
Thoughts?
Hello??
Anyone???
I've been keeping an eye out for one. (for you). So far only seen an am version. Seems to be kind of hard to find.
That is very kind of you, sir, thank you!
I was really only looking for recommendations, but yes, leads on something cheap and suitable would be nice as well. Icon_thumbup
Russ - thanks but I think I'm going to stick with my Sencore for now. I moved your post into For Sale or Trade as you requested. Thanks again, much appreciated.
