Threads: 569
While awaiting my transformers back from Heyboer (the speakers came yesterday from Sound Remedy) I decided to take a quick look at my Hippo. I bought it this winter, or around, and cheap - about $60. Very clean unit.
With an excellent original back etc.
Now, the first thing I need to ask - what's the least painful way to extractthe chassis? I realize I need to desolder the antenna, but I am concerned with the dial string assembly: is there a way to remove the chassis such that I don't ruin it? I thought of taking the pulley off the tuning cap and tape the string to it but the pulley is pressed to the shaft, no screw.
How did you guys do it, or did you have to bite the bullet and restring it in the end?
http://www.nostalgiaair.org/pagesbymodel...013634.pdf
Threads: 54
Mike,
I'm trying to remember how it disconnects, I think it has a setup where it's pulled by a spring on one end, and the dial cord on the other, by that big drum pulley on top of the tuning condenser, so you slip the cord off the back of the pointer somehow. It's been a few years since I dealt with a hippo, but I can pull one out of storage and have a look.
(This post was last modified: 06-30-2017, 10:57 PM by Arran.)
Threads: 569
Thanks, Arran. I'm sure it's simple but it isn't obvious, and I'd like to minimize the possible PITA when putting it back together.
Threads: 569
OK, it is very simple. Just taped the cord to the pulley so it stays in place and it is released by simply pulling the hook spring on the pointer.
Now desolder the antenna and this is it.
Threads: 569
Not bad, rebuilt the triple electrolytic.
Used dual 12uf 170mA 45V caps, they fit well inside the tube. I ended up with all three being 24uf which is (should be 30, 22, 20) OK.
Tomorrow will try to restuff the tubulars.
Threads: 268
I knew you could do it Mike!! Like Arran I did one many years ago and just couldn't remember how it comes apart.
It's easy when you know how!!
Threads: 569
I hope if nothing interferes tomorrow, I'll be able to finish the recap.
There has to be at least one bad tube as the power wires show open while the power switch is closed.
Will find out.
Threads: 54
Mike; Terry;
I had a look at one of my Hippos last night, the cord that moves the pointer has a loop on one end that fits over the hub of the pulley on top of the tuning condenser, and then feeds out of one of the slots in the pulley, and then over to the clip on the back of the dial pointer. I don't know what was on the end of the cord where it clipped onto the back of the pointer as that end had apparently snapped off and disappeared, but it was probably a knot to keep the cord from slipping through. It's actually a fairly ingenious dial cord arrangement, they found a nice and simple way to move that pointer rather then going through some Rube Goldberg arrangement of pulleys and loops like some British or European radio would use.
Threads: 569
Whew! Finished the recap and changed 2 or 3 resistors that were off too much.
I don't know if someone did some repairs, all looked factory to me, but the wires are as new, so no wire replacement had to be done.
I will power it up (provided I have all tubes) some time this week.
Threads: 54
Mike;
Since it's a 1948 model, Philco had probably switched to more modern vinyl wire covered wire by then for everything rather then mixing and matching with the rubber/gutta percha covered wire. About the only shortcoming regarding later Hippo production was the introduction of those mini IF cans on some production runs with the junk silver mica caps inside.
Threads: 569
Oh, forgot to add: there is that "special" cap, 0.2uF that is "polarized" and used as a 465kHz trap; I obviously did not have that one and I did not know the number of turns it would take if I decided to make it a "coil over cap" trap, so I rejoice in the fact that, restuffed with 0.2uF, it will look original and will act as the chassis-to-common tie cap, and as for the trap, it is no longer the issue anyway and is not needed. (It is the C19 as shown for code 121).
Threads: 569
So, good news is: all the tubes test good. The open circuit was due to one of the 7B7 loctals having oxidized pins, so even after testing well on the tester it would not complete the circuit upon the re-insertion, at which point I simply scraped the pins and then it worked out.
I brought it up on my Variac, saw the pilot lamp coming on, simply waited for the tubes to glow, spun the tuning cap pulley, and without the loop antenna connected got my local station where I expected it. It plays nicely, no hum.
Now the chassis need light dusting and the case need some cleaning and maybe polishing.
Some pics:
Before and after recap:
Threads: 569
Before/after
And some more.
I am not sure if I should perform an alignment or leave it be.
Will decide tomorrow.
Threads: 69
City: Kansas city, MO.
Very nice job.
Threads: 268
Looks good!!!
What should I offer?
I am not sure what radio it is, but seems like a 1950 AM/FM set. Or from 1948, possibly one similar to 48-1264.
In any ...morzh — 12:44 PM |
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM |
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM |
Ron
From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM |
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM |
91H Code 126 Restore
Hi Nick,
Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM |
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM |
I'm pretty sure that the dotted line I circled in an earlier post signifies that it is applicable to the 226 model which...RealRider — 08:05 AM |
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
There are currently 3987 online users. [Complete List] » 2 Member(s) | 3985 Guest(s)
