Threads: 91
City: Jonesboro
State, Province, Country: AR
Fellow Philco Phans
I'd appreciate some help.
I just picked up this 1936 620F, and it has been worked on. Most noticeably, the grill cloth  . I plan to replace it, but the backing is a flimsy cardboard.
Would anyone happen to have this or a similar model that would be so kind as to get a tracing or a good quality pic of the original grill board for me
[Image: https://farm5.staticflickr.com/4207/3554...6d9c_k.jpg]
[Image: https://farm5.staticflickr.com/4257/3484...4c3a_k.jpg]
Thanks in advance!
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 242
City: West Bend, Wisconsin
Not sure if this will help at all, as it's a model 625, which may or may not have the same backing board, but this reassembly video shows how it looks beginning at around the 6:40 mark:
https://www.youtube.com/watch?v=tCkg_QaDCno
Threads: 91
City: Jonesboro
This will do! Thank you very much!
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
One more Question: I'm in the process of recapping, and need to know the values of the tone control. Part No. 30-4316.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 69
City: Kansas city, MO.
Looks like 0.02 or could be 0.01 kind of hard to tell. and 3 or 5000 uuf. 61 & 61a on schematic.
http://www.nostalgiaair.org/pagesbymodel...013804.pdf
(This post was last modified: 07-03-2017, 09:54 PM by KCMike.)
Threads: 214
City: Seattle
State, Province, Country: WA
It's a bit clearer on this scan of service bulletin 218A:
https://drive.google.com/file/d/0B64cfWa...sp=sharing
0.02uF in the tone control for 61.
0.003uF tubular for 61a.
BTW - nice radio Jeff!
Threads: 91
City: Jonesboro
Thanks Nathan!
Hopefully this 620 will go smoother than my 1st!
Took me 13 months to get my 1st up and running.
So far it's going well.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
I made this video a couple nights ago. It's up and running.  I have a reproduction dial on order from Radio Daze, and a grill cloth from Richmond Designs  . I'll wait until I get the dial in before doing the alignment, as the one on there now is incorrect.
[Video: https://youtu.be/vzbKkz7eZyc]
Blessings,
Jeff W.
Jonesboro, Arkansas
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
