Philco PT-49 - Repro Photofinish
Very nice!!!
Nathan that is a Super job! Icon_thumbup Icon_thumbup Icon_thumbup
M R Radios   C M Tubes
Looks Great! Icon_thumbup
"He has all the virtues I dislike and none of the vices I admire." — Winston Churchill
OK,,now you can run off about a 100 of them,,,and you can sell them on E-Bay,,,,CHEERS
Icon_think Yeah..... I could retire.....
Icon_lol  Just kidding - the decal design is free to download from the Gallery.
If anyone else has a PT-49 in need of reproduction photofinish and isn't able to print it themselves just PM me. I'd be happy to send a copy your way.
Thank you for the step by step how to instructions. I will try to duplicate your great results on an old FADA F51 with a strip of walnut burl on the bottom of the cabinet.
Thank you for your inspiration
Nice work Nathan
Thanks guys!
pbert - good luck on your repro photofinish!
Philco 91 Tuning Condenser
There are currently 9140 online users. [Complete List]
» 1 Member(s) | 9139 Guest(s)
