northern Electric finished
I bought this Northern Electric tombstone radio about three weeks ago and now it is all finished.
   I found that the transformer had a shorted secondary, so I used a new one I had bought for my rogers 10-12 .
 then I found  that the choke somehow got a hole in it and about 20 wires were broke. I got another one from a good friend of mine  and after all that work, the radio plays very well.
 It does not have a dial but rather a backlighted dial that rotates as you turn the knob. For a different band, a different color rotates around
  The cabinet  took the regular amount of work , stripping ,staining and toning.
Now it is a keeper.
 Dan in Calgary.  PS here is a link to the interview that I gave to the CBC .
It is about 5 minutes long.
http://www.cbc.ca/news/canada/calgary/programs/homestretch/people-who-fix-things-old-radios-1.4192174
   Living in Calgary Alberta
Beautiful Radio Dan, and your interview was really good. Thanks for posting it.
Very nice looking piece, Dan.
I love it...
Super job on the cabinet... A++
Icon_smile
That's a beauty. I love the dial, very classy.
Greg
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
