Philco Model 70 Cabinet
Hello Guys
Does any one know what type wood was used for the Tiger stripe Trim on the 70 Front??? Never have seen Walnut with that grain.
Thanks
Bob Icon_smile
Bob
Here is the veneer used, according to Furniture History:
Arch panel - Oriental Wood
Instrument panel - Half Round Black Walnut
Top and Ends - Half Round American Walnut
mrphilco Wrote:Bob
Thanks Ron I was hoping that is what it was.
Cheers,
Bob Timms NC
There are currently 8921 online users. [Complete List]
» 1 Member(s) | 8920 Guest(s)
