Threads: 569
Now the question:
Look at these pictures of the band switch.
You could see on the first a solder lug on the bottom wafer, next to the large white do-hickey that's just bent up and is not soldered to anything. Is it like so in your radio?
And the second bothers me: you could see how on the same wafer, at the same more or less place (I just focuse my macro lens on a different spot) the white wire (to the right of the red) goes to the contact that is raised on a blob of solder and it is above the level where it wipes the sliding contact when it moves by. Though the contact seems to touch that blob. The contact is the third one counting from the stand-off that holds the wafers. What the heck is it and what do you have in its place?
Threads: 154
City: Westland, MI
Mike, sorry, I don't have my chassis out. Now, however, I have a reason to. Will look tomorrow. Take care, Gary
Threads: 154
City: Westland, MI
Mike, without my schematic or chassis in front of me I'm going with a couple of hunches. The 41-280 does have a gimmick wire in it - that might be your unsoldered wire. Also, if this chassis is like the 41-255 chassis, the white block is a duel mica cap block. At work right now, so can't check to be sure.
Take care, Gary
Threads: 569
Gary, no, the gimmick wire is in the tuning cap.
Threads: 569
Well, I aligned it, mostly IF and moved the pointer using the local 1160AM station and then my generator.
After that the was very little other trimmers did.
I have lots of stations on Bc, a few on Police, especially between 5 and 7MHz and very few on SW after dark, with a short wire for an antenna.
I will listen to it when assembled, now waiting for my rosin to come in to add traction to the cord.
But so far I am not impressed. It is not a sound I would admire. Very.....mediocre.
Maybe I'll sell it. Though maybe I'll leave it for the collection as the sole rep of this style.
Threads: 50
City: Shenandoah,
The schematic for your 41-280 looks similar to my 41-250. I am very pleased with the performance of the 41-250 for sensitivity. With the built in loop I find it gets plenty of stations plus a lot less noise and static compared to my 37-116 which uses a long wire antenna. The 37-116 does beat the 250 for sound quality though.
Ron
Bendix 0626. RCA 8BX5. RCA T64
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
Threads: 569
Ron
I meant the sound. The sensitivity on AM is just fine, but sound-wise it is not just below the 37-116, it is below 18 or 111, that is radios that were not exactly top of the line and were 8-9 years older.
Acceptable, yes, but nothing remarkable. I'll defer my final judgement until it is all in the cabinet, but most times one could infer the performance listening to the speaker on the bench.
Threads: 268
So Mike what are you going to do about it????
If it where mine the 7c6 would be gone and a 7F7 in it's place. 1N34 replaces the diode section of the 7c6. 2nd triode used as a phase inverter. Should give a little more gain which will compensate for the loss in some negative feed back to boost the low end up a little.
I know I have too much time on my hands!
Threads: 569
I don't improve upon radios, I restore them.
Plus, it is my impression that the speaker is at least partly responsible.
Threads: 569
Well, it ain't so bad after all. Not your 37-116 but in the cabinet I could justify keeping it.
I was waiting on the piece of rosin I bought on eBay for 90 cents and free shipping to come, which it did today, so I dissolved it in some pure isopropanol and with a cotton swab soaked the cord a bit in it so it stopped slipping, after which I put it in the cabinet. It is playing as I am writing this.
Some pics.
Playing aglow (could not do it in the dark)
This concludes the restoration.
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
