Threads: 91
City: Jonesboro
State, Province, Country: AR
And here is a shot of the chassis with the re-stuffed caps in place, and the new cord installed.
[Image: https://farm5.staticflickr.com/4289/3506...46d8_b.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 91
City: Jonesboro
I attached a spool of antenna wire. I slowly powered it up on the variac, and didn't get anything, then I realized the variac wasn't plugged in.
I plugged it in, and tried again. I wasn't sure which thumbscrew to attach the antenna to. 1st attempt, I got audio, but no radio signals, so I powered down and tried the other screw. Upon power-up, I immediately got static, so I dialed across the band. Everything came in on the dial where it should, so I didn't perform an alignment. For this video, I attached a 12 foot length of wire, and plugged it into my outside wire which runs 50-75 feet out in the backyard. This is a little cheap 4-tuber, so it doesn't have AVC. It's really obvious as I tune across the dial....
[Video: https://youtu.be/ewMVZBNpLPw]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 310
City: Kings Park NY
I dont remember this one...
I like it!
And you already have it going!
Slow down buddy, You might get a ticket at that speed
Me
AC: 4 DC: 1
Threads: 91
City: Jonesboro
Since I'm fixing the images from Photobucket, here's an update: A "studio shot" of it all back together and done.
[Image: https://farm5.staticflickr.com/4298/3587...317c_b.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 310
City: Kings Park NY
A++
AC: 4 DC: 1
Threads: 55
City: Lexington, KY
Looks good Jeff
Since you live in CA you should buy a set of Floyd Paul's 3 booklets,
Los Angeles Radio Manufacturing, The First Twenty Years:
http://www.antiqueradios.org/paul-bks.html
You might find a picture of your set in one of his books, they're very informative.
(This post was last modified: 07-12-2017, 01:44 PM by Eliot Ness.)
Threads: 91
City: Jonesboro
(07-12-2017, 01:42 PM)Eliot Ness Wrote: Looks good Jeff
You might find a picture of your set in one of his books, they're very informative. Thanks! I'll keep this in mind  . I also have a slimly documented Flint that came out of the same factory.
Blessings,
Jeff W.
Jonesboro, Arkansas
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
