38-60 Top Veneer Orientation
Getting ready to do the cabinet work on my 38-60B.  The veneer is completely missing on the top of this cabinet, and I have a total noob question.  What is the correct orientation for the top piece of veneer?  Should the grain go front to back, or left to right?  My guess is left to right, but not sure.
Jon
You guessed correctly. There are two 38-89 on epay (same cabinet)
Thanks Terry!
I have another question for all you cabinet experts.  The side walls of this 38-60 cabinet are warped inward near the back of the cabinet.  Here is a photo of one of the side walls with a straight edge lying on top.  The total deflection is about 1/4" or perhaps a little more.
I realize this is an (almost) 80 year old cabinet and it doesn't need to be perfect, but I would prefer the sidewalls to be straight.  At the same time, I don't want to risk splitting the wood or damaging the veneer in the process of trying to straighten it out.
Would you recommend trying to straighten these sides?
And if so, how would you go about doing that?
And finally, if I was able to straighten the sides, what is the probability that the walls would just 'return' to their present state of warpage?
You will need 2 strong wood braces vertical cut.
Thin, maybe 1/8th x 1.5"
You can hard clamp the back for a while to set it strait if you like but the wood is not really stressed there...
I would add the 2 braces from right under the arch, inside on the sides of the cabinet down to the base of the cabinet.
You will have to make sure you can remove the chassis before gluing in permanently...
Thanks Kirk.
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 4484 online users. [Complete List]
» 2 Member(s) | 4482 Guest(s)
