Transitone TH 4
I need to find a schematic for a Transitone TH 4, I am a newbie and the radio I have does nothing but buzz. I am going to recap it but would like to be able to read the schematic and follow voltage etc.
http://www.nostalgiaair.org/PagesByModel...014241.pdf
Enjoy,
-Bill
I have the info from nostagiaair but was looking for more detail
Then please contact Chuck at the Philco Repair Bench. He can provide high quality photocopies of any prewar Philco home radio, and at a reasonable price.
Details here:
http://www.philcorepairbench.com/schematics.htm
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6346 online users. [Complete List]
» 1 Member(s) | 6345 Guest(s)
