PHILCO Type-025 Ohmmeter
I recently came across a PHILCO Type-025 Ohmmeter and am unable to locate any information about it. Does anyone know anything about it? When were these produced?
I can post a picture if anyone's interested.
Thanks.
You mean this:  http://www.radiomuseum.org/r/philco_circ...r_025.html
A scanned copy of the 'Philco Radio Test Equipment Manual' has been uploaded to the Phorum for us. It's available in the Downloads section:
http://philcoradio.com/phorum/showthread.php?tid=17130
It covers the Model 025 tester along with many others.
Yes...that's the device I was looking for info about. Thank you!
That's the item I was looking for. Thank you!
Philco 91 Tuning Condenser
There are currently 8746 online users. [Complete List]
» 3 Member(s) | 8743 Guest(s)
