schematic needed for 38-93b
Further to my search for a circuit with a previous posting, I may have identified my radio after receiving my copy of Antique Radios by John Slusser. Would any one have a copy of the above model please ?
Rudy
Rudy,
A note on this radio a radiomuseum.org says that you should use service info for 37-93:
http://www.radiomuseum.org/r/philco_38_93b_2.html
The schematic can be found here:
http://www.nostalgiaair.org/PagesByModel...013228.pdf
Carl
Northern Panhandle, WV
Thanks for your reply Carl. Unfortunately the tube line up on Radio Museum did not line up with mine, also I couldn't get into Nostalgia Airs site for some reason. I shall keep trying.
Rudy
Rudy,
What is the tube line up in yours?
Carl
