silvertone 6156 console
Hi guy's,
Have a line on a Silvertone 6156 console.
Does anyone know anything about this radio?
I can find specs and schematics online, but no pictures.
Is this a hard to find model or what?
murf
Hey Murf,
Took a look at the diagram and it's nothing spectacular. No rf stage, single IF amp, does have p/p output (6v6's).
Probably good for abt 5-7wts of audio. Would be much easier to fix than a RCA 812K.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
