Philco High Efficiency Aerial instructions?
Would anyone happen to have an original copy they might sell or post pictures of the instructions that would have come with the 1937 Philco antenna system? Just bought one that is complete parts wise but is missing the instruction booklet...
I have a bunch of originals but what model?
I believe the info is in the manuals themselves...
Unless you mean the original arial set up by philco that comes with the lightening arrestors and cables to mount the antenna.
Kirk
Nope, just need the manual that would have come with the antenna... It is complete except for this... I believe you are right that the model number is on the manual itself... Cant find anything on the box... Here is the listing off of Ebay, it is for the 1937 model year... Dont know if there where different aerials for different models or if this antenna set up worked for all Philco models for the '37 MY... http://www.ebay.com/itm/Philco-High-Effi...true&rt=nc
Ok,
 I scanned it in color and Black & white. Send me an email through the forum or message me your email addy.
It is not a manual though, it is a one page instruction sheet that came in the box. I hope it is what you are looking for.
Icon_smile
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6801 online users. [Complete List]
» 1 Member(s) | 6800 Guest(s)
