Threads: 567
I was about to give up. It was receving across dial after all. But yesterday scoping outthe distortion I thought was coming out of the detector, I realised whatever was there did not explain the output waveform from 43. I even changed the grid bias resistors that are supposed to be 300k and were 500k. I saw a sawtooth after the DC blocking cap from 75 to 43. So I noticed the two caps, the DC blocking and the shunt looked the same and the shunt was supposed to be 500pF and both caps were 4.7nF.
So I changed it, and....voila.... It plays really nice and really loud. The freaking shunt was killing everything.
The guy who recapped this radio made at least 3 screwups that made the radio not working properly.
About it.
Threads: 268
Stoopid NF capacitors!!!!!
Threads: 567
Plus the grid cap on the 75 had bad connection and had to be resoldered, sometimes it would go to garbled sound and react to tapping, after soldering it's ok. So in case it starts doing it again, change the 75 tube.
Ok. Done. Officially.
PS. Dude, stop buying these.... handicapped radios. They are totally botched and are actually challenging even for those of us who actually know the difference between the caps you charge and the caps you wear  Buying a non-working unit someone else tried to fix and failed is buying the result of their ineptitude, which is problem upon problem upon proble. The grid dap was the only problem the guy did not cause himself. All three problems I fixed he introduced. The radio was working before he decded to recap.
Threads: 337
City: lawrenceville nj
Come on mike that's the fun of it getting it to work
Threads: 567
No, it's no fun. Fun is fxing an old radio, but fixing others mistakes, especially when they're many, ain't no fun.
Threads: 54
Mike;
I ran into that in a post war Philco I bought off of another collector at his garage sale. One of the mica caps must have been bad, so he replaced it, was originally a 100 mmf/pf cap and he put a .01 in it's place. He also hog tied a 50 year old axial lead 450 volt cap to the back of the speaker's rear bracket because he didn't have room for it under the chassis, thankfully he did not recap the rest of the set. The odd part was that he used to be a com tech in the air force, so he must have done these things, the set didn't work, so he gave up on it. So as you say, dealing with other people's problems, I didn't mind so much though since I got it pretty cheap.
(This post was last modified: 09-07-2017, 01:17 AM by Arran.)
Threads: 567
Heck, yeah, if I get some very sought after radio for a song, unless it is totally hosed, it might be worth it.
Problem is, when the radio goes bad on its own, you just replace the bad parts.
When someone rearranged it in some creative way, you have to figure out wrong connections.
Well, it is working now, that's what mattress
Threads: 310
City: Kings Park NY
I'm glad It was not me...
Good job,
Unfortunately I'm selling it.. I would have enjoyed it for the last 2 years but you had the chassis
Right now it is 1937 Philco's..
AC: 4 DC: 1
Threads: 567
I did not have it for two years. Maybe for a year.
Philco will have to wait.
Threads: 310
City: Kings Park NY
I was kidding Michael
I'm in no rush for the Philco 610.
I meant I have to concentrate on buying Philco's for my display...
AC: 4 DC: 1
Threads: 567
Please buy good Philcos
Preferably without RF mezzanines and sub-boards underneaths. And without rubber-coated wires. And not "dealt with before".
It’s been too cold to solder in the garage the last couple of evenings, but it has allowed me more time to search for th...jrblasde — 07:23 PM |
The part/tool you get from HD is inside the plastic, like in a bubble.RodB — 07:17 PM |
Got it. Still did not get the "Bubble" part.morzh — 07:10 PM |
No Mike. Clear plastic from the packaging of items you buy at Home Depot, the ones you can't open without a hack saw or ...RodB — 05:48 PM |
Philco 89 indicator light.
Well thankfully that did not happen.Jim Dutridge — 05:21 PM |
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!
PS. Looked it up. They have kits and parts for mod...morzh — 02:45 PM |
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!morzh — 02:39 PM |
46-1201 Trip Switch Spring
I deleted the other thread, as it was duplicate and did not have the photo.
Please proceed with this one.morzh — 02:37 PM |
Hello, first post here, bear with me.
I've been electronically refurbishing a 46-1201 that I received from a relative. ...ConcernedFeller — 01:46 PM |
I am late to this post, amazing amount of work for a speaker Mike. You must like the challenge. I have a speaker from an...Paul Philco322 — 01:04 PM |
There are currently 8225 online users. [Complete List] » 1 Member(s) | 8224 Guest(s)
