Philco 57C
What kind of wood am I dealing with and what color of lacquer should I use? Is the grove aroung the front and the grill cutouts suspose to be of a darker color? How about the grill cloth itself? Thanks for the advice and all the help you have been in the past.
David Woodward
Walnut veneer; Medium Walnut or Perfect Brown toning lacquer overall with no two-toning effects; Philco 70/90 pattern grille cloth.
Eico 232 VTVM Schematic
