Please ID this Silvertone
If you are concerned abt the diode you could parallel  another w/it or use a 1N5408 (1000v 3A). Disconnect the 240 ohm cord and replace with the X connections.
Thanks Terry.. I will give it a try..
Skip...
Well finally finished up on this..Cabinet cleaned up pretty good..
[Image: https://farm5.staticflickr.com/4420/3722...4569_b.jpg]
[Image: https://farm5.staticflickr.com/4489/3722...61cd_b.jpg]
Sounds good too..
[Image: https://farm5.staticflickr.com/4491/3739...0884_b.jpg]
PS I guess I do not know how to include a Video..
Skip...
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
