GE Model 200
Working on a GE Model 200.. Question
How do you get the glass out without breaking??
See pictures..
[Image: https://farm5.staticflickr.com/4447/3674...2236_b.jpg]
[Image: https://farm5.staticflickr.com/4484/3741...fa6c_b.jpg]
Thanks
Skip...
I believe,, they are clips-- that flip open---out-----BUT could be __WRONG,,,,and they JUST ,,lift a little to get glass out??????//// they also look like fansworth clips,,,with a little wedge in them ,,to hold that main part tight,,and down ,or against the glass,,,,,Can't really tell from this point of vision,,,----hope that may HELP-----CHEERS
Yes.. Was able to get glass out . One clip broke on right side and was able to slide glass from other two..
Thanks All
Skip...
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
