GE FE-112 Dial Pointer
I'm all but done with the restoration on my GE FE-112, but I'm missing the dial string indicator for the Off/On/Tone section of my dial face.
Any ideas where I can find something that will work? This is the volume indicator...I'd need another one just like it.
PS-Image is sideways.
[Image: https://scontent-iad3-1.xx.fbcdn.net/v/t...e=5A39D9DE]
http://www.ebay.com/itm/Huge-Lot-Assorte...SwqF9ZvwpM
http://www.ebay.com/itm/Antique-Radio-Pa...Sw3eJZz7Cr
Yeah. I saw those too. I was hoping to not blow $50 on a hodge podge of parts only to find none of them worked....
Well, this one looks like something that one could easily fashion out of a piece of a tin can cut with scissors, bent appropriately and painted red.
To get an exact match you might need to buy a parts chassis or get real lucky on eBay.
You might be able to find and modify a pointer from a different set to look pretty close.... when it's all closed up you probably only see the tip of the pointer anyway.  This is where a Dremel tool, small files, tin snips, etc. come in handy.
I bought some aluminum roof flashing from Lowes or Home Depot a few years ago and it looks like it would be pretty easy to cut and bend.  I can cut off an index card size piece and mail it to you in an envelope if you send me your address.
I made a pointer out of sheet metal from the cover of a wrecked Sony home theater map, and I mean wrecked. I sort of cheated though, I didn't make the pair that slide along the track and slips over the dial cord, I got that part from a broken dial pointer off of something else, and then soldered the strip of sheet metal from the Sony cover to it. I pretty much had to make it, it was a dial pointer for a Guild Spice Chest radio, it was a metal strip bent into a loop that was supposed to poke out through a slot in the middle of the dial, the G.E one will be easier since you already have an original as a model.
Thanks for the offer, but I just "reboxed" it and will enjoy eventually hunting down a replacement. My daughter set her sights on this one so it should be in the family for a while.
[Image: https://i.imgur.com/CTRUz2O.jpg]
That's one spiffy looking set!
A big ole 11 tuber. One of the most selective sets I've done. Best SW reception of any set I've worked on.
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 10798 online users. [Complete List]
» 1 Member(s) | 10797 Guest(s)
