  • 1 Vote(s) - 3 Average
Philco 44B clamshell cathedral
I did... it didn't...
OK, was just curious. Sorry.
NO problem. I was curious too!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
