42-380 recap
I'm recapping my 42-380. Im almost done with the exception of 4. Does anyone know an easy way to get the 2 line filter condensers out of the power block? And how to get rid of all the black filling? Also there are 2 other caps that are hard to get to. One is under the board and the other is below the bias resistor and buried in wires. Anyone have any suggestions?
Have a look at this thread for how to restuff bakelite blocks:
http://philcoradio.com/phorum/showthread.php?tid=9107
There are lots of these guys in Philco radios. Once you get used to them they're not bad at all - and I find them much easier to restuff than normal cylindrical paper caps.
The speaker table error?
Philco 70 antenna lead
