1933-34 Philco 89B Restoration
Threads: 91
City: Jonesboro
State, Province, Country: AR
Jumping back into this Model 89. My workshop is filling up, and I need to start fixing and selling the sets I don't intend to keep. Label on the back of this one says it is a Code 121. My other 89 that I plan to keep is a Code 123.
I just went through my Cap stock and pulled everything.
Question: Bakelite Block 4989-W: The 200 ohm resistor: Is a 1 Watt replacement sufficient?
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 72
City: Linn Creek, MO
I would just reinstall the original wire loop. It's better than any resistor you could put in there.
M R Radios C M Tubes
Threads: 569
The plate current of the 39/44 tube (if the resistor is the one in the Cathode of it in parallel with the cap) is 6mA max, which will make the dissipated power 0.007 W (7mW), which means that any small resistor will do just fine.
If you could re-use the wire resistor that was there - great. Otherwise use any power you have.
Threads: 268
This might be a little after the fact but those cloth covered wire wound resistors don't take kindly to flexing or movement. Typically resistance wise they are very stable and should stay in tolerance. Just don't bend it.
Threads: 11
City: Bellmawr, NJ
Don't Breath on them,,,and no heat on ends,,,
Threads: 91
City: Jonesboro
I wound up replacing the resistor in the bakelite block with a 1 watt I had on hand.
This block and 1 other were done last night.
Electrolytics were replaced today.
I did a quick check of the transformer, some of the coils, and all the resistors.
All checked out, so I decided to turn it on, running it through my variac.
Here's a video I shot during the 1st power up test. All stations came in where they should on the dial.
[Video: https://youtu.be/uxNjHNX4wvs]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
Last post, showed the radio up and running. I patched a couple pieces of missing wood in the upper part of the grill, did some touch-up work, and gave the cabinet a new coat of toner over the original, and a new grill cloth from Richmond Designs. It went to a new owner just before I left for my trip earlier in January. New owner is really happy, and I'm glad to start thinning out my workshop, and make a little money off the hobby. Here's some glamour shots before it went to its new home.
[Image: https://farm5.staticflickr.com/4578/2712...00f3_b.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 569
Looks very nice, Jeff!
Threads: 271
City: Wilsonville
State, Province, Country: OR
91H Code 126 Restore
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
Philco 70 antenna lead
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.Jim Dutridge — 04:34 PM |
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
There are currently 2885 online users. [Complete List] » 2 Member(s) | 2883 Guest(s)
