Simpson Model 305 Tube Tester
I have a Simpson model 305 tube tester with an operator’s manual dated 1954 which contains tube chart data. I am wondering if there are any newer tube chart data that can be used to test 1965 era tubes, such as, 6EU7 and 6GW8? Icon_confused
I've never seen any. Coletronics produced data books for several popular testers after their manufacturers gave up on them, but I don't know about Simpson.
Why not just go to Simpson's website, Tech Support page and make a request there.
They still have Model 260 multimeter info online, maybe they can help you.
http://www.simpsonelectric.com/main/inde...al_Support
Chuck
Thanks Chuck. I'll try them.
Bob
Chuck,
It was a good idea but Simpson said they don't support items that are more than 7 years obsolete.
Bob
There are currently 8442 online users. [Complete List]
» 2 Member(s) | 8440 Guest(s)
