Correct grill cloth for 16B cathedral
What is the correct grill cloth for a 16B cathedral (5 band)? I've seen pictures with a white plain cloth (on mine now) and others with a brownish "chevron" pattern.
Thx
If you are talking about the cathedral, shown here:
http://www.philcoradio.com/gallery/1933b.htm#c
then you want the 70/90 pattern, which is pattern #1 from Radio Grille Cloth Headquarters:
http://www.grillecloth.com/
Yes that's my radio and it currently doesn't have the correct grill cloth.
Ron, thanks for the info.
Another question regarding the 16B cathedral:
What was the original veneer species used on the case, Walnut or African Mahogany?
Thx
Walnut . Thats a good looking set .
Philco 91 Tuning Condenser
