Tube Shield Color
I'm not sure if this is the right place to post this but, what color were these tube shields originally?
Sometimes they look like they were painted green, sometimes brown, and sometimes it just looks like a patina.  Icon_crazy
These are from a 37-610. Thanks in advance.
Kelly
"He has all the virtues I dislike and none of the vices I admire." — Winston Churchill
The tube shields on a 37-610 that I recently restored were unpainted. I simply polished them up and sprayed them with gloss poly.
It looks like they were plated, could be tin, like a regular tin can.
Really nice job! Icon_thumbup
These shields were originally tin plated. The tin came off over the decades on most of these shields.
10-4. Thanks guys. Icon_biggrin
Whatever you do with refinishing the shields make sure you wash them good first, tube shields seem to build up a layer of black dust on the inside, and sometimes the outside, not to mention oxidation, and sometimes rust.
I had kinda wondered that myself. Found some paint I think may be close. Kind of a brownish color to me.
Tim
The (few) shields that stil have good tin plating are very shiny, almost as if they were chrome or nickel plated. Not brown.
Yeah, I would not paint them - unless you polish them up and put on a clear coat, maybe semi gloss.
If you have a large solder pot, you could try an experiment: clean and flux a shield , immerse it in molten solder, then twke out and shake of the solder, strongly.
I tried plating some lantern parts takes lots of 95/5 solder best to find at a flea market. Placed app. 8 lbs in a old cast iron pot heated until liquid. Parts must be very clean no grease or oils on metal. You will need acid flux or zinc chlorite(sp). Best done outside use gloves, face shield and a fan to keep the fumes at bay. Having done this several times to get a few parts just right. I would not do it again. David
I did a lot of pot soldering back in the old days.
If you really want to make these look new, get a plating kit from Caswell. Build your own power supply and save a lot of money.
Not great pictures, but, I replated a lot of the parts for this radio:
https://www.russoldradios.com/blog/number-two
And I did all of the parts on this radio less the chassis, which I probably should have also done. I could have purchased all of the tools and materials I needed for what it cost and I would have saved months of frustration (dealing with the guy that plated it).
https://www.russoldradios.com/blog/into-...ratosphere
If I understand correctly, these shields turn this color with age? They are shinny inside, but the outside sure looks like some kind of thin paint and just a touch of rust in some spots. Be better to clean and clear coat? Wire brush or steel wool? These are from the 610 (my forever project).
Tim
The speaker table error?
Philco 70 antenna lead
