Threads: 91
City: Jonesboro
State, Province, Country: AR
I have this 1929 Philco 95 Lowboy with a broken Grill. Can any of you wood/cabinet experts out there tell me what type of wood was originally used on this part of the broken grill I'd like to make up a replacement using the same type of wood or veneer. Thanks!
[Image: https://farm5.staticflickr.com/4117/3487...2c90_b.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 147
City: Dallas, TX
Looks like walnut veneer over the thin layered plywood.
Threads: 54
I think it was French walnut in particular, what cut doesn't matter. The grilles used in the 1928-29 "Lowboy" style console cabinets are almost as notorious for breakage as the Philco 20 cathedrals are. I think that the solution is to acquire some Baltic birch plywood of a suitable thickness, and then laminate it with some French walnut veneer, and then cut it out. Although if might be easier to check with Steve Davis about this, it's such a common problem that he may be replicating replacement grilles for these by now.
Threads: 112
City: Medford OR (OR what?)
As I can recall - which might not be too good - these might be birch plywood without any other veneer. Using stain and toner to match the cabinet.
I think that later examples were sold without the grill at all.
Threads: 112
I just looked at the one in our bathroom. The grain and color match the area of trim below the cut-out. So it is either walnut or mahogany. Just sand an area of the original. If it is pinkish or orange it is mahogany. If it is brown or reddish brown, walnut
Threads: 337
City: lawrenceville nj
Umm
you have a radio like that in your bathroom
Threads: 112
yes. And it isn't in the bathtub.
Threads: 91
City: Jonesboro
Thanks for your help guys.
phlogiston: do you use it to sing along to "Singing In The Bathtub"
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 310
City: Kings Park NY
Is it so guests can put on music so no one can hear them ...... You know...
AC: 4 DC: 1
...careful...we have rules against "bathroom" humor...
Quote:I. Permitted and prohibited discussions.
A. The following types of discussions are not allowed in any part of the Phorum:
- Any personal attacks of one member upon another.
- Any libelous or potentially libelous postings.
- Any discussions of a lewd or pornographic nature.
- Any postings which may be considered as "spam".
- Any discussions of a political nature.
- Any references to bodily functions, or any type of "bathroom" humor.
Likewise, usernames that have anything to do with "bathroom" humor are not permitted and the user will be banned.
This is intended to be a family-friendly site.
Threads: 91
City: Jonesboro
I'm off-season from my job, so I'm working on some projects I have been pushing to the back of the cue. I decided to make an attempt at making a new grill for this 1929 Philco 95 Lowboy.
I picked this up July 2016 at the Alameda California Historical Radio Society's annual swap meet and auction for $10.
This is the condition it was in when I brought it home. The radio is complete, and unbelievably has never been serviced.
[Image: https://farm5.staticflickr.com/4324/3503...a8d6_c.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
I finally pulled the crushed grill piece out, and took it down to a store here in town that sells veneer. I asked the experts there what type of wood it was. The consensus was Mahogany that has Toner on it, possibly Walnut color.
[Image: https://farm5.staticflickr.com/4545/2492...1961_c.jpg]
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
I used Photoshop, a scan of the piece, and pics of another radio with the grill intact to create a template of the grill pattern, and printed it out.
[Image: https://farm5.staticflickr.com/4528/3876...dbe3_c.jpg]
I have had a good size sheet Mahogany on hand for quite some time left over from another repair, so I cut a piece off, and applied it to a small piece of nice plywood the correct thickness.
Using the printout, I rubbed some pencil on the back, then laid that down on the wood, traced it out, which transferred the design like carbon paper onto the wood, then used a fine tip sharpie to trace the pencil.
[Image: https://farm5.staticflickr.com/4581/3876...48cd_c.jpg]
[Image: https://farm5.staticflickr.com/4527/3876...548e_c.jpg]
The next step is to cut it out.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 18
City: Mesa, AZ
WOW. I really like that model! Looks like your on the right track for the repair. I can't wait to see the phinished results! What an excellent phind!
Threads: 112
---another one of those threads that I lost.
Anyway, the model 95 in our bathroom:
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
There are currently 8724 online users. [Complete List] » 1 Member(s) | 8723 Guest(s)
