Zenith 5-S-319
Would like to know ,,, Icon_clap Icon_clap Icon_clap if someone can get the parts list (schematic) off the Radiomuseum site for Me,,,,Need to know  The size of speaker Icon_question Icon_question Icon_question Icon_question and ALL other parts,,,,I just don't understand ,,,WYE,,,they make it ,,SOO,,hard to get into that site,,,,----Thank You for all your Help, Icon_thumbup Icon_thumbup Icon_thumbup ,------CHEERS
I have the same trouble with it sometimes.
Maybe this will work for you.
http://www.nostalgiaair.org/pagesbymodel...025008.pdf
Thank YOU,,,,,for all your Help
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
