Philco 16B Tombstone Speaker P/N Question
I recently acquired a Philco 16B tombstone cabinet with speaker (no chassis), late version (rounded top).  The speaker does not have a part number stamped on it.  I have the early "flatter top" version and the P/N for the speaker is clearly stamped "H13".  Do all 16B tombstones use the same speaker?
Geoff, all 16B tombstones use the H-13 speaker.
M R Radios   C M Tubes
Thanks!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
