Philco 60 Warped Dial
Is it possible to flatten this warped dial?  Otherwise, Radio Daze has an excellent reproduction.
[Image: https://farm5.staticflickr.com/4232/3505...3c61_n.jpg]
Henry
I had a similar looking dial on my 81. Just popped it off the shaft, laid it on a flat surface, gently used a head gun and a small piece of wood to flatten it.
How did you pop it off of the shaft without breaking the rivets?
Right. The rivets would be a problem, but I can leave the dial on the shaft and make a U-shaped press. If it'll stand up to the minimum heat to make it plastic--that's what I needed to know. If necessary, the rivets can be replaced with small nuts & bolts. Thanks.
<How did you pop it off of the shaft without breaking the rivets?
Let me rephrase, I removed the dial and it's bracket from the tuning capacitor shaft by loosening the set screw.
Let me clarify.  I didn't mean to leave it on the shaft, but to leave the dial riveted to the metal.  I was wary of melting or burning the dial, so I heated, pressed, and cooled three times; increasing the heat each time until it softened adequately.
[Image: https://farm5.staticflickr.com/4313/3512...a48cac.jpg]
It worked. Thanks for the help.
Wow, great tip. Thanks for posting!
To follow up on flattening the warped dial.  Even when I thought I had successfully flattened the dial, it warped again after 24 hours.  For my final attempt, I totally removed the plastic, heated it almost to melting, then kept it clamped flat overnight.  That worked permanently.
But I bought a repro dial, anyway.  Here's the way I removed the old dial and attached the new one:
Cut off the rivet heads from the back of the dial.  Affix the new dial with golf grip tape (thin, double-sided adhesive).  Stick the rivets back in the holes and hold them in with a dab of epoxy putty from the back side.
[Image: https://farm5.staticflickr.com/4314/3600...bcc48e.jpg]
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
42-345 Resistors
Great comments. I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM
There are currently 1555 online users. [Complete List]
» 1 Member(s) | 1554 Guest(s)
