Philco 16B Tombstone Speaker P/N Question
I recently acquired a Philco 16B tombstone cabinet with speaker (no chassis), late version (rounded top).  The speaker does not have a part number stamped on it.  I have the early "flatter top" version and the P/N for the speaker is clearly stamped "H13".  Do all 16B tombstones use the same speaker?
Geoff, all 16B tombstones use the H-13 speaker.
M R Radios   C M Tubes
Thanks!
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4759 online users. [Complete List]
» 2 Member(s) | 4757 Guest(s)
