Wood Type Used
Need to make a few of them wood patterns,,,maybe for other people on line ,,MAYBE ??? CHEERS
That looks like luann plywood, otherwise known as "Philippine Mahogany", which is not even close to being a real mahogany. I think that the original grille had some tulip poplar veneer on it, and may have been poplar all the way through, it has a grain very similar to the unfinished part. The luann ply is very frustrating to cut cleanly, it is soft and chips all over the place.
There are currently 8584 online users. [Complete List]
» 3 Member(s) | 8581 Guest(s)
